V2 Perforated Build Plate
Can anyone shre with me what advantage to going with the V2 perforated build plate?
I'd like to hear the answer to that question, too.
Mike
It’s thicker so it warps less. Less warping means even contact on the bottom which leads to even thermal transfer; the end result is better raft adhesion (less part warping).
Can someone post a picture of V2 so I can try and see if I have V1 or V2?
v1 is 1.5mm thick and v2 is 3mm thick
