My nozzle is always dirty. This is problematic because it regularly drips black... (see photo).
Could you imagine a little sponge located in a top corner of the frame where the nozzle could regularly (once each 5 minutes for example) come to rub itself while printing ?
Thanks for reading this. More thanks for considering my idea :)
That is a good idea, I know of a major brand starting with an S that does that. A dual nozzle machine that extrudes a little between layers support/build material and at the same time moves the nozzles through some type of wire brush. Don't know if there's a patent for that, the comapny in question does have some to it's name and isn't fearful of using lawyers ;)
I still can't imagine it dripping black in the middle of a white print unless it was on the outside of the nozzle or whether it is just burnt white filament
It occured while my nozzle touched a corner of my print that warped detaching itself from the raft.
Then, there was a lot of filament everywhere. My noozle and my hotend became dirty with burnt ABS...
On the photos you will see a burnt filament traped into the layers and a dirty drip near the Z hole. These photos where at the opposite side of the lifted angle.
I would really like to see a software based solution for the string that hangs down every time a print starts. The stepper should retract slowly to avoid the string.
I always pull it away by hand right before the z calibration.
I clean it once it starts traveling, but by the time it hits the plate there's already some oozing out. This leaves a thread of plastic that can mess up the raft if not removed. A retraction while sitting/zeroing would make things a LOT easier - click print and walk away.
