axel
December 6, 2016, 12:49pm
#1
I have printed this object many times. (Also with older versions of Z-Suite and firmware) without any problems.
But now it’s badly printed :
They are printed in pairs.
But here, only one object has the default.
Printed in Z-ABS cool grey.
0.19
Light infill
What problem can cause this kind of defect?
I specify :
M200 V4 of 2015
Firmware 1.05
Zsuite 1,61
The hotend + nozzle are new
The thermocouple cable is new
Would this be the extruder + PCB cable?
Would this be the right model (see photos)?
I've seen this with a bad cable or connection. I'd try reseating the cable (both ends) and perhaps even moving the parts around into different locations within Z-suite to see if the problem moves with the part (highly unlikely).
axel
December 6, 2016, 3:26pm
#3
Thank you for the answer.
In fact, the thermocouple cable broke (frayed) and there was smoke near the connector !
I replaced the cable but now the printing is bad on some objects (see photos).
Maybe the cable of the extruder or the PCB is damaged ?
