ZSuit has started to take up to a minute to import even the smallest stl file. I add a file either via the + button or drag and drop and the guy does nothing at all for up to a minute then imports the stl.
Hi, Paul.
Please, try cleaning ~/.config/Zortrax catalog (keep in mind that if you have any customized printing profiles that you want to keep, you can save them for later in some other catalog). If that doesn’t help, try reinstalling the Z-SUITE.
Can you tell me your computer specifications? Which Z-SUITE version were you using before?
