Z-SUITE 1.9 is here!
We are introducing electrostatic discharge resistant material - Z-ESD* along with the awaited TOP layers modifier. The recommended values are set as default.
Full changelog below:
- New material - Z-ESD*
- TOP layers quantity modifier is back (the recommended values are set as default)
- Fixed issues with manual FAN settings
- Fixed scaling rounding issue (http://bugtracker.zortrax.com/tracker/issue-191-resizescale-values-rounding/)
Fixed steps counting on M300
Fixed with 1st and 2nd layer mixing (http://bugtracker.zortrax.com/tracker/issue-180-first-project-layer-double-slicing/)
Fixed handling bigger files (300mb+)
Fixed M300 print cost calculator
Renaming FLIP to MIRROR FLIP
Fixed minor bugs with: thin walls infill, spacing between raft and model, seam preview, file loading, units conversion
It’s available through autoupdater or through our website:
- In order to print with Z-ESD, it’s required to update your M200/M300 firmware to 1.0.6 version, available here: (M200 & M300 )
Bugs could be reported through Bugtracker
