Thanks for the update! Fan control is a great feature!!
Just wanted to let you guys know that the slow loading issue with XP is unchanged. Tried the stan.stl today and it still takes 4 min for 1% progress. Is it planned to fix this? I have no problem if it takes time for a fix… just would like to get some feedback if you can even reproduce this on your side…?
Stan.stl is ASCII. When you open stl file with any text editor and will be able to read point coordinates then it’s ASCII. Binary stl is not readable by human. Easy to notice the difference when you will see it. Seems as simpliest explanation I can give
[quote name=Martin Olchanowski][quote=Winstonc]I am using Windows 7 and Stan and Cartman take forever to load (never loaded them as I give up) Other models load fast.
There is a pattern…Binary .STL load fast. ASCII STL load slow.
When I have the slow loading with ASCII STL the software is not frozen. I can move/resize window, open other applications and I can close the Z-suite normally at any time. Processor runs between 50% and 75% the whole time while loading, laptop fan spins up. Memory usage: When I start the z-suite it uses 70mb, when I load stan.stl it jumps to 150mb instantly and then it hovers around that. I still have around 300mb of memory left.
Here my computer specs:
2ghz core2 with 1Gb Ram
ATI Mobility Radeon X1600
I know…not the latest rocket but all I can say is that runs everything else totally fine. For example all the tested STL files open within a few seconds in the UP software (both…Binary and ASCII).
I’m thinking hardware is the issue with the large files. All of the South Park files take me about 4 second to load. Running Windows 7, i7 3.5ghz quad core, 16gb RAM, 2GB EVGA video card. I’ll try all of them on my old XP machine tomorrow. I already know Stan takes forever on that box.
Yes Andre, thanks for those informations, now I know better where to look for the issue. Till it will be fixed I would suggest you to use some external software to convert ascii to binary stl if possible.
