Just got spare parts - PCB v4 and Ribbon Cable V2, and changed my PCB first - it didn't solve the problem.
Then I changed the ribbon cable, put the machine on the table on its left side, unplug from electric, opened the down fan part to reach the inner motherboard, after that I unplugged the Ribbon cable and plugged the new one (to see if its the problem but it seems like the extruder-feeder motor is the problem...) after that I try to switch on the machine, plug in the electric etc.
I can see the blue light blinking on the motherboard but no start up sequence on the screen or in the motors.
As far a I can remember: The cable came with a converter, I take out the converter - call that end A. I Plug the "A" to the mobo, and "B" to the extruder.
I will double check that and inform asap. If it was my bad, well I'd be quite happy :) but I demand color notes on the Ends ,)
