Hi!
My Zortrax M300 does not print symmetrically. It is strange that asymmetry occurs along diagonal of the print bed not along X or Y axis. The problem is so serious that you can see this assymetry without using caliper. I have performed maintenance method with JIGS (https://support.zortrax.com/m300-axes-maintenance-with-jigs/) but it did not help at all.
Has anyone else run into this issue and if so do you have a solution?
Karol
