Hi, in zsuite at the first time i saw 3 nozzle avaiable, i have all of them. i used 04 nozzle for 3 week and today i’ve changed to 06, set on the machine but i can’t see anymore the other option in nozzle diameter tab in zsuite.
Uninstalled, cleaned cache and temporaly files but nothing, do you have a solution please? i’m stuck
Hi, @3dtutto.
Keep in mind that 0.3 and 0.6 nozzles option is not available for all materials.
Make sure that you check the same type of material.
Thank you, now i can explain why, it’s a big limitation for the potential of the machine, i’m sad about this cause i bet all on this, why this discrimination? however hope in the future, thank you again
We’re working to add this option for other materials as well, so stay tuned
Hi !
I have the same problem ! it really is a problem to print quickly, even with PLA !
When will this problem be resolved ?
