Here are a couple quick shots showing the improvement between 0.0.3 and 0.0.4 in regards to the seam. The first two were printed using .19 and the latter the new .14 layer heights. These are straight off the machine with no clean up other than raft removal. I noticed on the .14 print there was a small blob on the right front leg. Not sure what caused this.
Keep in mind that this frog is only 400 long. And apologies for the average macro shots.
Using 0.0.3 .19mm
Using 0.0.4 .14mm
