2.6 Prints mesh with infill.
As title says. I slice a model with Mesh (no infill) and the sliced model always produces one with infill. I think this is due to how Z-Suite fixes a file, but it won't import otherwise.
As far as I know mesh always creates infill, because it closes the model with a roof. But shell with 2 or more perimeters should do what you want.
regards
Andi
Please send me the model via PM.
Hi, sorry it's been so long.
I’m still getting this error, but I’ve found a way around it.
If I import ANY file and slice with mesh setting, it will slice it as a solid the first time I do it, despite the final result saying it was sliced with mesh.
Then if I go back, add some infill with the slider, remove it back to mesh THEN reslice, it will slice with mesh properly.
This has been a repeatable glitch every time I’ve used 2.6.0 on mac.
I’d still be happy to send you any mesh I’ve used it with, but its still a thing that happens with EVERY model I import.
regards
Andi
For me, mesh has never ever used infill, and shell leaves holes in the top/bottom of a print and is unable to use support material (i'm using Z-Ultrat settings). Like I said in my other post, reslicing it with the same settings again will get me the hollow result I want.
It's totally possible that the process of fixing the file causes the issue.
Anyway, I need the stl and the zcode to investigate it.
