The feature I was waiting for was the bug fix for the Z dimension on Z Suite 1.4.1.
I do not know why it has been fixed at the firmware level (Z dimension was still ok with Z-Suite 0.0.9.6), but i can confirm it works now (with parts i tested)
So if you use Z-Suite 1.4.1, I think it’s compulsory to update to 1.0.1
With firmware 1.0.0 or 0.8.0 and Z Suite 1.4.1, parts are a bit deformed on the Z axis, height is smaller than expected. Actually, it is like Z Suite is configured with something like a 99.5% scale on Z axis, part is a bit squeezed.
It took me days to realize it, when i had to print a replacement part for one of my others printers, it was 59.5mm instead of 60mm. I though first it was normal due to abs cooling down but then when I compared to the same part printed on Z-Suite 0.0.9.6, perfect height. I though it was a Z Suite issue but that was a firmware one (obviously)
I can confirm there was errors in the Z-Axis with the 1.0.0 firmware. I have been printing some parts for my quadcopter, and then switch to the 1.0.1. The same zcode generated with Z-Suite 1.4.1 in the SD Card produced a bit taller piece with the 1.0.1 firmware. Why?
