Any sample with Z-GLASS and Z-HIPS
I'm wondering about the products which is printed with Z-GLASS and Z-HIPS. Anyone ordered them? Could you please share some of photos? Thanks in advance!
Better than this for example?
http://i.imgur.com/20Mx9uc.jpg
This model with you showed on your link is after post-processing. Somwhere on google I saw the instructions how to processing PET material, but this is very time-consuming.
Same request here, any example for Z-Glass?
The filament just came out less than a week ago no one is going to receive it faster than standard shipping unless purchased from the zortrax retail store give it some time.
In regards to post processing Aleksiej you should be able to apply this technique that does not require much effort http://www.taulman3d.com/t-glase-optics.html
I will post some samples on friday.
That shot glass looks like it was made using SLA (solid) rather than FFF. For a single walled shell the result will probably be ok but if there is any kind of internal cavity produced by infill material or even just small gaps between parallel strands of a double walled shell you won’t get anything like that level of transparency. It will look more like an ice cube full of air bubbles. I remember being disappointed after I’d printed a cube in clear abs on the UM2. You definitely can’t see through it.
Tech, no-one except resellers.
If it hasn't been for some delay in processing due to USD rampant change and the usual processing time.. We should have had this materials since last week.
Hi everyone, name is Rick from Vancouver Canada and just received my M200 on Dec 22 and new to this forum. I just put in an order on the Z-Hips and put a pre-order for the Z-Glass. I will definitely post some pic's, as I am very excited to see what this material can do.
