Anyone actually see a 30% print speed increase in 1.4
Professional options for use as in what?
Rapid test by printing without raft
change speed, flow, temp
use PLA and others
vase mode
real full infill print
random seam functional
know where is the seam in the display
Have a file or a display with all the settings of the print
Edit 11-12 :
I quickly responded last time but what is lacking in Z-suite also is the possibility of
- having several different filling density in the same print
change the type of filament, not just color, in the same print
- print small parts successively in a single print
I know this is a big job … But the machine is really amazing and the software is too restricting…
What new machines you have ordered ? I search a machine with 350x350mm in X,Y with the same Buildquality as Zortrax M200 ?
Sorry, I don't know yet a machine with this print volume and the same print quality as M200.
Maybe DELTA WASP 40*70 ?
Stumbled upon this one, but I know nothing about it.  http://www.3ntr.eu/en/
Michael, the claim for 30% speed increase was for the high speed option only, did you compare accordingly?
I used the same settings across both versions without using the faster mode on the new software, this was a simple one to one comparison. I was not looking for a faster print time and it was just an observation that the newer software is printing slower (maybe t has been a build up in surface quality adjustment). I was only looking for a way to get less infill on a mini-nuke model, damn thing weighs a lot.
-NS
A friend sells these. Work very well, but are considerably more expensive than an M200.
I saw the WASP at Makerfaire NY and I was really, really impressed by the build quality, features, ease of use, and reliability. They must have had like 20+ of their smaller delta running all day, play a 5' tall delta and a 7'+ tall delta printing. On top of that they have a ceramic attachment that worked really well and was easy to install to their existing extruder set up. Overall their extruder was pretty interesting too and they claim it has great exotics support.
