Are Nfep and ACF films usable with Inkspire?
Hello, is it possible to use either nfep or acf film with Inkspire printer ?
Which thickness should I use if that’s possible ?
Thank you
our FEP is 0.035 mm thick when folded in two layers (one that is in direct contact with resin, and the other that protects the first one from sticking to the LCD display). We’ve spent months on testing different configurations and thicnkesses of FEP films to provide the best and reliable quality, however, if you believe you can achieve better results, you can use any, even single-layered, 0.01-0.2 mm thick FEP films. Please just remember that a FEP film that has only one layer may contribute to LCD screen deterioration.
