jchod
December 5, 2018, 11:46am
#1
In my M200 the extruder started being a little to loose on the bearings, and it does not move smoothly.
I would like to replace the bearings and possibly linear rails.
What brand should I use to get the best results? Also what are the dimensions?
Marta
December 5, 2018, 3:07pm
#2
Hey there. You can contact us via support form and purchase original parts (https://support.zortrax.com/support-form/ ).
Just in case, linear bearings are LM6UU.
The linear bearings sit in the extruder block with some set screws, might want to check those first; if they loosen, you can get some play, if too tight they will bind/damage (they are very sensitive to how tight on setscrew).
