Hi everyones, I tried to get a better prints quality on thin walls by setting 0.3 nozzle on my M200+ (with the latest firmware, and latest Z-suite versions) and as you can see on my picture, the result is disappointing…
I have used the same settings for the 0.3 and 0.4 nozzles, instead off setting 0.3/0.4 nozzle on the specifications…
That is to say for the 0.4 nozzle:
Estimated print time: 0h 57m
Material usage: 2.64m (6g)
Printer: Zortrax M200 Plus
Profile: Derniers paramètres
Support type: Automatique
Support: 0°
Material: Z-ULTRAT
Nozzle diameter: 0.4 mm
Layer: 0.09 mm
Quality: High
Infill: Solide
Fan speed: 100%
Seam: Régulièrement
Outer contours: 0.00
Holes: 0.00
Surface layers Top: 9
Surface layers Bottom: 4
Support Lite: Oui
Smart bridges: Oui
First layer Density: 100%
First layer Print speed: 100%
First layer Flow ratio: 100%
First layer gap: 0.23 mm
Raft Enabled: Oui
Raft layers: 6
Platform-raft gap: 0.20 mm
Raft Density: 100%
Raft Print speed: 100%
Raft Flow ratio: 100%
and for the 0.3 nozzle :
Estimated print time: 1h 56m
Material usage: 2.76m (7g)
Support type: Automatic
Support: 0°
Material: Z-ULTRAT
Nozzle diameter: 0.3 mm
Layer: 0.09 mm
Quality: High
Infill: Solid
Fan speed: 100%
Seam: Normal
Holes: 0.00
Surface layers Bottom: 5
Support Lite: Yes
Smart bridges: Yes
First layer gap: 0.19 mm
Raft Enabled: Yes
Raft layers: 7
Platform-raft gap: 0.22 mm
Raft Density: 100%
So is someone can help me to hunderstand why the thick walls, witch are 0.85mm thick, are better with the 0.4 nozzle, and disgusting with the 0.3 nozzle … and the thin walls, that are 0.55mm are well in both case…
By the way, I notice that the printer is very fast to make the thick wall, then I guess that this fast make the printer vibrating and loose maybe in accuracy…
And I have check the plateform calibration…
Thank you in advance, and sorry for my bad english
Flo
