When laminating z-suite to print on the zortrax inskpire 2 there is no possibility of copying the models with the supports, this is a problem when making several identical pieces, sometimes you have to configure the supports because such density or size of the end is not necessary due to smaller details or internal holes and by not being able to copy the object with the supports, a configuration that should be minutes turns into hours.
Hi @rubenalpux
While we do not currently have a way to copy supports or objects with supports, you can use the Replicate zcodex2 function, which is available in the preview step. This function will replicate the model along with the supports.
Just make sure to export the zcodex2 file after you’re done replicating the models.
