Hello! I have a question if it is ok that some belts show a little degradation. The more i print the more copper becomes visible. If it's ok so it will stop doing that some time later - i'll deal with it :)
or should i just move some pulleys? Will i void the warranty doing it?
The printer is a V4 model. Total print time is only about 30-40 hours
I had something similar with another printer (other brand), it was caused by a wrong mounted pulley but it was glued and the axis assembly had to be changed.
I would suggest opening a support case and show this support (they officialy do not monitor the forum), not doing anything yourself on a brand new printer.
it looks good I got belt wearing with my second Zortrax (it was easy to fix) if any displacement exist then belt looks hairy and hairy means it growing heavy fur at every hour of print
what was the cause in your case and how did you fix it?
