What are the best materials for parts that have to withstand high temperature?
I found two different material data sheets that claim different numbers for Z-ULTRAT Vicat Softening Point (98 and 128 C).
(They're attached. Every Zortrax material data sheet I've downloaded seems to present a different set of parameters for each material. Makes it hard to compare which material is best for a given application. It would be great if Zortrax could prepare a single spreadsheet comparing the same parameters for each Z-material.)
Also, FWIW, I have Z-GLASS, Z-PETG, Z-ULTRAT, and Z-ABS on hand. Which of those is best for high temps? (I just ordered some Z-PCABS too; it hasn't arrived yet.)
