I read the support topic to replace the bottom fan, very noisy on my old M200.
But : I can't find a replacement fan : "70 x 70 x 10 24v". It's quite easy to find a 70x70x15, but not 70x70x10.
Can I try a 15 mm ? Any supplier ?
Ted
Ted
I ordered this one from Amazon and its been working fine for the past month or two.
https://www.amazon.com/gp/product/B00XP5B5A6/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
About $10 in the US with free Prime shipping.
In my printers the noise is from the fan in the power supply, not the MB cooling fan, which is very quiet. I don't recommend opening the power supply to change the fan, but there is a trick to reduce the noise somewhat - cut out the aluminum grille from the power supply enclosure in front of the fan.
Thanks Michael and Julia.
Ted (a recent Z****P owner !)
Maybe I've just had bad luck, but all 3 of my Zortrax-original fans have failed and each showed signs of heat damage.
Noctua.
No 70 mm fan at Notua ...
Noctua.
Yep, and that's what I used for the extruder fans but as Ted said, Noctua doesn't seem to make 70x70 mm fans so I just took a chance on that Amazon listing. So far, so good.
I believe that any 70x70x10(/15)@24 would fit.
Thanks Marcin.
I confirm, a 15mm should fit. I opened the printer, but I had been unable to find a 24V 70x70x15 at a european supplier, only from China or Honk-Kong, 3 or 3 weeks shipping to France ... So my very old fan still making noise !
