Yes disabling of fan cooler will help just in current release seems that disabling of it don’t working and it is always on, also for very big models it is good idea to use “LIGHT” or “MEDIUM” infill type.
I noticed a little ‘burning’ on a white part I created too but it wasn’t much. I assume it was caused by the head moving slower in that area. Since it was on the outside I could just scrape it off though.
Is it cold in the place here are you using your printer? It happened to me with a large model I was working on, the ambient temperature descended below 15 degrees C and I noticed that started to happen. I am building an acrylic enclosure to reduce the impact of the weather in the quality of the prints. I recommend you to do the same or at least change the place where your printer is working.
[quote name=ACC]Is it cold in the place here are you using your printer? It happened to me with a large model I was working on, the ambient temperature descended below 15 degrees C and I noticed that started to happen. I am building an acrylic enclosure to reduce the impact of the weather in the quality of the prints. I recommend you to do the same or at least change the place where your printer is working.
[/quote]
Yes 15C is too less as environment temperature, 21C or more is the best and 27+ is a perfect fail safe temperature (summer time).
[quote name=Martin Olchanowski][quote=ACC]Is it cold in the place here are you using your printer? It happened to me with a large model I was working on, the ambient temperature descended below 15 degrees C and I noticed that started to happen. I am building an acrylic enclosure to reduce the impact of the weather in the quality of the prints. I recommend you to do the same or at least change the place where your printer is working.
[/quote]
[/quote]
[/quote]
That’s a problem for me, my City it’s at 16C all the year, maybe I have to thermicaly issulate the printer with some kind of panels???
[quote name=Scentapio][quote=Martin Olchanowski][quote=ACC]Is it cold in the place here are you using your printer? It happened to me with a large model I was working on, the ambient temperature descended below 15 degrees C and I noticed that started to happen. I am building an acrylic enclosure to reduce the impact of the weather in the quality of the prints. I recommend you to do the same or at least change the place where your printer is working.
[/quote]
[/quote]
[/quote]
Yes we are working on it, just now only suggestion is to keep room temperature at place where is printer at 21C+.
[quote name=Scentapio]That’s a problem for me, my City it’s at 16C all the year, maybe I have to thermicaly issulate the printer with some kind of panels???
[/quote]
Temporarily you could try putting cardboard panels or something around when you print but Zortrax is working on making their own panels.
