This is a small issue, but printers like the Inventure tend to build up quite a bit a filament debris in the bottom of the machine. In future design iterations, it might be nice to have a lower tray that users could easily slide out to remove and clean. I envision something similar to a toaster. Anyway just a thought. Keep up all the awesome work.
At this moment the best solution to the remove debris is the use a car vacuum cleaner like this:
Thank you for your suggestion, we appreciate it. Still, Aleksiej shared an interesting suggestion regarding the way of removing material debris.
