I am using Z-suite a lot, reloading models and see how they render with different thickness etc.
Getting Z-suite to create the zcode sometimes takes quite some time and I have seen that it uses maximum two of the 4 cores I have, some times only 1.
Would it be possible to support more cores, ie make it more multithreading? That way Z-suite could speed up tremedously. (my next laptop will have 8 cores)
I know that sometimes this is not possible due to the nature of the processing: not all calculations can be done in parallel…
