Yesterday I ran a 3-hour print, no problems. Scraped and cleaned the bed and hooked it back up like always. Today I switched on the printer, selected "Unload Filament", and the extruder will not go past 78%. Switched it off and on, unplugged and re-plugged the head connector, problem persists :(
Welcome to the downed M200 club! Mine has been down since June 16th. The team has told me they have sent parts several times, yet I've received nothing. I hope your support issue will be handled better then mine.
Did you check set screws for the heater cartridge and temp sensor Julia? Just a thought...
Yes, I tightened all the screws. DIdn't actually pull the wires, but I don't think it's an open circuit since it does get to 78%...
julia,
themocouple may need to be replaced..
julia,
buster that sounds about right, that has happened many times to me in the past with "manufacturing extruders".
