Changing Input Voltage from 110 to 220V
Hello, I currently have a zortrax m200 in the United States and I need to ship it to Peru which runs on 220 Volts. How do I switch the voltage so that the printer can be operable over there? Please advise quickly if possible. Thanks!
Hello @seths28,
Thank you for your patience.
The power supply unit of the M200 model operates in the range of 110-220V, so there’s no need to switch anything. Just make sure you have the correct connector cable for Peru.
Damian
