Hello there,
Can I use the support nozzle as main nozzle ? I will order new ones but until they come I want try support nozzle in hottend A if it is possible.
Hello there,
Hi @Cntk3D,
this is exactly the same nozzle, so yes, you can swap them. Please just note that if it gets clogged with model material residues - it might no longer work with the support model then because of the difference in the extrusion temperature. However, you could then set a higher temperature (280-290 Celsius degrees) during the material loading to try to clean the nozzle and get rid of possible residues - this might do the trick.
Best regards
Hi Karolina,
I hope you are doing well.
Are both nozzle diameters same? I mean both nozzle diameter 0.4 mm? Thanks for your replies.
Have a nice day.
