try also this http://support.zortrax.com/eliminating-axis-problems/
I mean it prints but the noises I know are not good. Also I use this for my business so I really can’t be with out it. Right now.
I have tryed the axis problems it better little noises some times. But it’s printing so gonna leave it till something I guess breaks. Zortrax wants a video but don’t want to send them the one i posted here because that sound stopped now. Not a well build printer I can say that. My Flashforge never had problems like this!!
hello, I'll tell you my experience, waiting for printing to finish ..
this is the picture of the screw
https://drive.google.com/file/d/0B8zRzc83Vho3bUlNTDZneGdFYUU/view?usp=sharing
Ok thanks for the info. I think I got a lemon here. I can’t even pass the calibration now. I hate this printer
People!!! Stop using the cal…it’s not worth it. Just use a credit card and be done with it.
No I can’t stand the paper thing. That’s how my other printer is and it have to play around with it so much. The cal worked great when I got this printer now it takes me 30 mins to get it to pass. Look I got this printer for that feature.
please check your email nick, I need some info from you.
ok sent the needed Info,
People!!!! Stop using the cal...it's not worth it. Just use a credit card and be done with it.
Credit card?
I use my calibration and it works perfectly. Everything is 0 except the center is I think 0.3 last time I checked it. Which I think the new V2 perf board would fix that, just hadn't got around to ordering it.
Ya thats
Credit card?
ya a credit card lol NOT something i would use. Calibration worked great until now i finely got it after 40 mins of trying! Im sending printer back to where i got it they are gonna check it out.
The autocalibration routine seems to work pretty well for me once I figure out how the elevation adjusting screws work and how their heads tend to get fouled in the perf board holes. At the least it is a quick way to check calibration.
Mike
Lol…I’m not using a credit card either. It was just the first thing that popped in my mind. I just calibrate it by eye (air gap) and sometimes just by observing the first layer… on the go.
Lol...I'm not using a credit card either. It was just the first thing that popped in my mind. I just calibrate it by eye (air gap) and sometimes just by observing the first layer... on the go.
Agree. With rafts, especially the ones generated by ZSuite (first raft layer is really a big one :) ), you do not need to have perfect calibration. You just have to take care of nozzle must not too close from bed (extruder would have difficulties to extruder, so clicking sounds) and not too far, because material won't go inside the small holes, so the raft would not stick enough to it.
Btw, I do not have any issue with auto-cal with a clean build plate…
Credit card?
... because bed seems pushed up by material from previous prints that go threw the holes; that especialy true for center, which is probably the most used part of it. Just cleaning it time to time is enough for me, and cal error goes from 0.5 to 0.1 I decide to do it when my ears tell me to ;), clicking noise is good indicator !
Laurent
Credit card?
I use my calibration and it works perfectly. Everything is 0 except the center is I think 0.3 last time I checked it. Which I think the new V2 perf board would fix that, just hadn’t got around to ordering it.
You just have to remove the debris underneath the board and scrape the backside…then the 0.3 will probably disappear.
