My M200 Zortrax printer shows the default code 034 and asks me to check endstops.
Is it possible to have some help?
Many thanks for your answer.
Pierre.
WHEN does it give the error ?
When extruder goes in the front left corner ? If yes you have to check endstops if is working, using a multimeter you can check is its faulty
Hello Pierre1,
this error can sometimes appear when the axes are misaligned and the endstops are not properly released.
Below you can find axes maintenance guide to perform:
Thank you for your help
I found the problem, the front up axle was dry, so after lubrication and auto calibration, my printer works perfectly.
Thanks.
