The printer is in a purpose built cabinet cabinet (clear windowed front with minimal ventilation) in an interior walk in closet. Drafts are a non issue.
Looking all over the website, it appears that either PLA PRO or HIPS are appropriate for low shrinkage large sized prints on the m200
What is the shrinkage rate of HIPS vs PLA PRO vs ABS?
Can the same hotend that has been used with ABS be used for HIPS? Any special treatment between swaps recommended if so?
How will PLA PRO hold up in a home environment when used as an audio cabinet over the long term?
As PLA PRO is biodegradable… what causes the plastic to begin breaking down and loosing strength – and how quickly does this occur?
What post processing options does PLA PRO accept?
What is the cost of a dedicated hotend?
Do any print speed implications exist due to the higher viscosity of PLA PRO when compared to HIPS?
$21 Z-ABS – High Shrinkage (Acetone & Mechanical post processing, Inexpensive)
$55 Z-PLA PRO – VERY low Shrinkage (Mechanical post processing only). Deforms at 120*F. Requires a fully separate hotend from other materials, must always eject material between prints, print in a room that is 77* or lower, and remove printers side panels as per https://support.zortrax.com/tips-for-printing-with-z-pla-pro/
$50 Z-HIPS – Low Shrinkage (Limonene & Mechanical post processing), high durability & impact resistance
Thank you!
Chris
Hi Chris,
Actually, Z-PLA Pro has the lowest shrinkage rate among the mentioned materials. In most cases, it does not shrink at all. We recommend to use separate, dedicated v2 hotend for printing with Z-PLA Pro, you can find it in our store: https://store.zortrax.com/
Detailed information about Z-PLA Pro may be found here (Technical Data Sheet & Safety Data Sheet might be useful): https://zortrax.com/filaments/z-pla/
I guess Z-PLA Pro won’t fail as an audio cabinet. Anyway, for functional and end-use parts, I’d rather use Z-HIPS.
Regarding the Z-ABS and Z-HIPS - yes, the same hotend may be used and there is no special treatment while using these materials.
