That’s better… lol
What’s up with the weird support in the front? The cross pattern?
looks like the X-Y axis.
Oh, it was part of the file… I guess it was made for printers that don’t print support.
Looking good, man !! I love dragons !!
Here’s a bigger dragon but only the head… I got the file from Thingiverse and it took about 6 hours to print. I used light infill and 30 degree support. The tip of it’s right horn broke off while I was removing support but it could be glued back on.
Nice print, but I thought you were going to scale it up to fill the Zortrax!
I scaled it up but only about 10%… I can print medium-sized objects without having problems with raft lifting up but when I go too big it does. Hopefully we get auto-cal soon then I’ll try something bigger. I could try sanding the bed to see if that helps in the mean time…
One thing I just thought of that I could have done was import the STL into TKC and add some kind of groove into the flat part to make it easier to hang up.
I cut keyhole slots in the bases of my dragons with a rotary tool for wall mounting, but yes, adding a hole to the model (after scaling!) would be more elegant
Nice dragon !
It might need a good hot air gun polishing, don’t you think it would make it better ?
I used a heat gun on it but only a little to remove some of the white marks. I may try it more in some areas that could use additional smoothing.
[quote name=Julia Truchsess]I cut keyhole slots in the bases of my dragons with a rotary tool for wall mounting, but yes, adding a hole to the model (after scaling!) would be more elegant
[/quote]
Ah yes, I’ll have to remember to scale it up first! I probably wouldn’t have thought about that and then ended up with huge holes…
What kind of costs does it take to print something in those dimensions?
[quote name=lupusk]What kind of costs does it take to print something in those dimensions?
[/quote]
What do you mean? The cost of the ABS? It doesn’t use much at all for that small size.
