I wonder if this will effect the weight of the print head assembly much. If it increases the inertia, it may produce printing artefacts due to effects on print head acceleration and deceleration, but might only be noticeable on high speed or paths with lots of rapid direction change. Let us know how you get on.
I have to say that I also see more disadvantages than advantages to this... I don't want any additional mass on the head. Is there really any (proven) improvement in print quality with two fans? Could you point me to some pics?
I will.. Printed the Zortrax bolt with 1 and 2 fans.. The threads did not look as nice on the left side of print. I'll try to find them.. That's why I added a second..
I really don't like the way these axial fans are being used. i.e pushing air into a surface right in front of them is very inefficient. I know lots of companies use them this way though. I'd prefer to see one tangential fan ducted and split to cool both sides. The tangential fan is designed for sucking air into the centre and blowing out the side. You could mount it vertically, away from hot end more easily as well. Wish I could work out how to copy and paste a link but it won't let me (anyway search for 40mm blower fan on google and you'll see what I mean). They would produce a much higher through put of air, more than enough for 2 or 3 ducting splits. There are only a handful of these types of small (40mm blowers) compared with the thousands of axial fans though.
I printed and use Julias Slip in dual fan from thingiverse (http://www.thingiverse.com/thing:1501068) . It works great, especially with flexible filament. But it´s necessary to disable the auto fan mode in z-suite because it will lead to an unexpected temperature drop error message.
lucky
it´s simple. If using the nocture fan, cut the yellow cable close to the fan (it´s not necessary). Connect the red cable with the red cable from the lower fan and the black cable with the black cable from the lower fan. All in all it´s a parallel connection. I connected the cable on the lowest level with a solder. But next time I will implement a connector so I can disable the second fan on behalf. The most tricky thing here is, to get the cable out of the metal housing :-)
The files are in the attachment. The "fan_mod1" part is made of 3mm aluminum.
I am going to make some reasonably priced kits. I hope I can prepare them until the end of the month, depends on the firms that do laser cutting and anodizing.
