Engine rebuild
I'm re-doing the magnetic engine I first built with the UP Plus 2 , this time I have super sized it to fit the Zortrax build plate . Hopefully it will be completed within a week
this is the old working engine link https://www.youtube.com/watch?v=A2G0-vBT2kc
1637
ehheh cooll!!
how can work? just with magnet?
ehheh cooll!!
It works like an usual V1 gas engine, he just used solenoid coil instead of oil and piston.
Your next project should be V8 engine. :)
LOL it's a little stronger than just a solenoid coil , it has 50mm rare earth magnet with a 58kg holding rate on the piston , coil design is also different , it intensifies the magnetic field to the center of the coil not outwardly creating a greater pull force , hahaha in the video when the counter balance wheel flys off , you can see it spin in one place and go across the table , the lead in the counter balance was 800grams alone , that engine also got upto to over 800rpm with a load (small genorator/alternator connected) , My new one is 65% larger using a 76.5mm rare earth magnet with a holding rate 168kg , unfortunately I need to find material strong enougn to hold together ,z-abs broke apart within 5mins under the stress
