Error #8 inskipire 2
The inskspire 2 printer has stopped mid-print and I’m getting the error: error #8 - could not communicate with the control panel.
The printer is locked and loaded with resin, and the print surface is too low to be removed.
Hey, thanks for writing about this issue. It’s best to contact support@zortrax.com regarding this matter. If you want to clean the printer, unplug it from the power source and then manually lift the platform upward. This will allow you to clean the printer before sending it for service.
