This is a program (Z-Suite v.0.0.5) error or something wrong with 3D model?
http://www.thingiverse.com/thing:55732
Error in file..You can repair it using Netfabb basic.
I run into that a lot with the new Z-Suite 0.0.5 there is a bug in the sofwear for shore .
Not a bug in Z-suite.. Bug in the STL file.. It is not a water tight model. Has missing faces.(really small ones) It came across as a surface in Spaceclaim. Not a solid.
Downloaded and checked on Netfabb, passed.
But not in Meshmixer. Applied the corrections and checked in Netfabb, little problems showed-up, corrected.
Here is the file: https://www.dropbox.com/s/lattzkt4bvbeh56/bumper%20%28repaired%29.stl
What software are you using to create the design?
Mike
Hello
I like to share that the new Z-suite 0.0.5 dose have a bug. After loading an STL file, the layer creation stopped at 96% for two hour.
Later I used the same file at the local 3-D print shop, and was working fine. I Use the software Ashlar-Vellum, Cobalt modeling,
(http://www.ashlar.com/3d-modeling/3d-modeling-cobalt.html), and Rhino 3-D. Not AL file are affected.
Dr-J
@Dr-J - Z-Suite V0.0.5 have some bug with slicing models, this was fixed in new Z-Suite V0.0.6 which should be available today.
BR,
Rafal
<strong>Z-Suite software for Windows*<span style="margin:0px;font-family:inherit;font-size:inherit;font-style:inherit;font-weight:inherit;color:rgb(11,214,177);">*</span></strong>
v0.0.6
<p>:D :D</p>
