hello everyone,
i have a new M200 plus printer, and on every print, every files (from zortrax too,so it.s not a model problem) external perimeters not have adhesion with infill.
i read some topic about that, but nothing works here.
if i set to 0mm the option «offset gap between perimeter and infill » , issue disappear BUT in this case the top layers of external perimeters are missing !!
so if i use default settings, print is not ok…
if i use advanced settings…print is not ok…
Someone have some infos about this?
