Is the fan supposed to blow onto the build plate ?
It's just that the fan on mine sucks air instead.
Hello Minestorm,
please note that the fan you see from top is some cooling fan for the print head. The fan which is supposed to cool down the extruded filament sits directly on top of the fan shroud, is not as obvious as the top one and starts to blow after the raft is printed. I also disassembled the visible top fan to turn it around until I realized that this is not the right one.
Olli
Thanks, I was just about to start taking it apart.
