I want to try different materials like wood or metal based filaments. Currently closed-source software does not let us modify temperatures manually. So that I have to use default printing profiles. Does anyone know extruder temperatures on current profiles?
A table would be great like;
Z-ABS : X degree
Z-ULTRAT: Y degree
Z-GLASS: Z degree
Z-HIPS: T degree
So we can pick the closest one or NEVER try if they are not close enough?
By mistake I started to print Z-Glass and now half of Z-HIPS square with Z-ABS profile no problem at all last time measured temperature: around 280C for Z-ABS I think Zortrax use additives for increase melting temperature and glass transition all they materials should be suitable for 240-300C
Z-ABS : X degree
Z-ULTRAT: Y degree
Z-GLASS: Z degree
Z-HIPS: T degree
You lose your warranty using other materials not produced from Zortrax.
