reporting an anoyance (rather than a bug)…
I’m using Z-Suite version 2.14.1.0 (I think this problem exists with previous versions).
In using external materials. I can change the extrusion temperature to a value:
if I change another setting (for example - layer thickness) the extrusion temperature is then always set back to 207:
If I do not notice this change, the print fails… which is anoying!
Simon
Hi Simon,
Thank you for your feedback. I passed your suggestions to the responsible department.
