I tried printing a linear bearing that I found online but the print failed miserably. I need those bearings to reduce the jiggle of certain parts I'm making while being free to slide up and down.
Any ideas why this happened?
attached are photos of failed print. STL and z-code files.
it worked well. restrained the jiggling while allowing free movement. I must start designing my parts with bearings. Thank you for ur assistance. I guess the previous design required a smaller nozzle or maybe it's the issue with Zortrax not printing thin walls.
Glad it worked. Drawn up in Designspark Mechanical.. Pretty sure it's no fault of the printer. The spacing between some of the walls was only .015" or .38mm That's just a bad design. Very low poly count as well.
