failed print
Mabey anyone can help me, I've got some problems with printing some part.
I try two times:
1) 0,14mm; Infill: medium; Support: 20; Fan speed: 40%
2) 0,14mm; Infill: full; Support: 20; Fan speed: 20%
With the same results.
Here you've got stl file and some photos
Which z suite version are you using?
Try with fan 80% or even at 100%.
the newest one (V 0.0.8 for Mac)
I would use 100% fan and rotate part 180 on z axis so the notch is facing the fan.
I'll try, thx :)
I use 100% fan and rotate part as #Kyle said and right now everything is ok :)
strange bugs... somethimes that happens on ssys machines too.
First attempt is to rotate part. ;)
