hello,
recently i bought an m200 plus, updated it with lastest firmware and z suite 2.8.2. I’ve done around 150hrs of printing and i had a couple of badly failed prints, see p
this happend a couple of times both using layers thickess bigger than 0.14 (0.19 and 0.29), and seems like that was due to warpage of the part and dislocation (raft was sticking very well to platform)
in this version of z suite i saw that you can first layer gap, and values are different from m200 and m200plus. with 0.14 i found a good compromise (mostly copyng values) but i have very little confidence with other layers size… I use z-abs… do you guys have experiencied this kind of issues and/or do you use diffrent values than the defaults?
|m200|raft|1st layer|
m200 | raft | 1st layer | m200 plus | raft | 1st layer | |
0.09 | 0.2 | 0.25 | 0.09 | 0.23 | 0.21 | |
0.14 | 0.2 | 0.23 | 0.14 | 0.23 | 0.26 | |
0.19 | 0.2 | 0.21 | 0.19 | 0.23 | 0.3 | |
0.29 | 0.19 | 0.42 | 0.29 | 0.2 | 0.42 | |
0.39 | 0.2 | 0.43 | 0.39 | 0.23 | 0.43 |
