I noticed that sending a projet with the same name fail when sending it to our m300 dual. After a first failure, the “print” button from z-suite wont work. I have to send and rename and then it works.
Its very annoying and a very easy fix. Simply rename the projects in the background using incremental numbers while keeping the display name sent with z-suite.
for instance :
display name : cube
background name : 20230119-0753
No conflict and everybody is happy…
