Do you have any reference or size for the transparent plastic tube in which the filament is guided to the extruder ?
Best regards
Best regards
diameters: 3mm inner, 4mm outer
edit: my bad
diameters: 2mm inner, 4mm outer
I'm measuring 3mm ID, 4mm OD? 2mm only leaves 0.25mm clearance in the tube from filament.
Yea, mine are 3mmID x 4mmOD
Thanks!
I ordered both size (id 2 and 3 mm), just before Marcin corrected his post.
