File loading problem
I used the beta without any problem. I updated to the latest version on the download page. I am trying to load a file into z-suite.
I get the following error message:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentException: An item with the same key has already been added.
at System.Collections.Generic.Dictionary`2.Insert(TKey key, TValue value, Boolean add)
at A.
at A.
at A.
.(String , Boolean )
at A…(String , Boolean )
at A. .(String )
at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ToolStrip.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.0.30319.34003 built by: FX45W81RTMGDR
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
ZortraxGUI
Assembly Version: 0.0.3.0
Win32 Version: 0.0.3.0
CodeBase: file:///C:/Program%20Files%20(x86)/Zortrax/Z-Suite.exe
System
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
ZortraxGUI&
Assembly Version: 1.0.0.0
Win32 Version: 4.0.30319.33440 built by: FX45W81RTMREL
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Core
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
Zortrax.Data
OpenTK
Zortrax.Data&
Accessibility
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
OpenTK.GLControl
Zortrax.GCode
Zortrax.GCode&
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
&lt;system.windows.forms jitDebugging="true" /&gt;
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
The file loads fine in the Afinia software and the Makerbot software. It also loads in the .3 beta that was released earlier. It just will not load in the current version.
I had an error once. Closed it then reopened. No more problems.
I get that error on certain files when I select to check integrity. Not sure what it means though…
I already tried closing and reopening. Then tried uninstalling and reinstalling. Still same thing. So far this is the only file I have had the problem with, but have only tried 3 different files since the official update.
The6uest, did it continue with the file when you received the error message? I let the computer sit for about 5 minutes and nothing happened. Maybe I need to wait longer.
Do you want to send me the file? I can check it on mine.
[quote name=dgtaylor45]The6uest, did it continue with the file when you received the error message? I let the computer sit for about 5 minutes and nothing happened. Maybe I need to wait longer.
[/quote]
Hmm, I don’t think it opened… or I may not have waited long enough either. I think I just restarted Zsuite then opened it w/o checking integrity. It seems to happen on more complex objects or those with some kind of drawing errors.
Maybe the Zortrax guys can explain what it means…
It is new bug which we found after 0.0.3 was uploaded on the server, it happen on certain models and only if “Yes” is clicked for check integrity option so just use “No” if model create a problems and then will be no problem, now this problem is fixed just v0.0.4 will be uploaded after few days.
Thanks, I always checked yes on the check integrity because I have been experimenting with so many design software to see which one I like best that I wanted to make sure I had not messed up a file. I will check no on any file that gives me the error until the update.
