Hi guys, today I tried to update the firmware to the new version 1.1.0 Unfortunately, the printer fails to update. I've already tried to format SD several times and change Sd, but nothing. What could be your problem?
<p><span style="color:rgb(33,33,33);font-family:arial, sans-serif;font-size:16px;">Hi guys, today I tried to update the firmware to the new version 1.1.0 Unfortunately, the printer fails to update. I've already tried to format SD several times and change Sd, but nothing. I attach a video of the procedure. What could be your problem?</span></p>
I tried to downgrade, but nothing. It seems that the printer does not read the SD card for updating.
Another problem I encountered:
When I try to print a template, I must go into the "Model" section three times (error message on the SD card) before the printer reads the contents of the SD card.
Ideas about it?
Thank you
Have you tried different SD card? Try hoovering SD card slot, some filament/raft leftovers could cause card reading issues
I`m having the same problem can`t update my M200 from 1.0.2 to 1.1.1, tried different sd cards but printer does not recognize Update.bin. So now don`t know what to do :(
