Firmware Feedback
Hm, true, interesting. Didn't notice that (only) the 90µm UltraT setting was changed somewhere between 1.4.x and 1.6.x since I never typically use anything below 140µm.
Is that intentional? It seems weird that Z-ABS >=90µm uses 0.5mm and Z-UltraT >=140µm uses 0.5mm but only Z-UltraT at 90µm uses three times the retraction.
Just checked: in v1.5 the setting for 90µm was still 0.5mm, so the change to 1.5mm happened when the way of storing the profiles was changed for the 1st time.
Is there a chance that something went wrong when converting the profiles from XML to source code???
No idea, gonna take a closer look at it tomorrow
Does the new firmware V1.1.1 address the issue with the build platform bottoming out? Any changes to calibration routine?
Sadly no, its was just an materials and Inventure integration :(
