Platform levelling. I reported this to Zortrax.When they first introduced nylon the buid plate leveling did not work as a curl of had nylon put a barrier between the nozzel and the build plate. A lot of “banging” went on while it tried. The end result was the nozzel “drilled” a hole in the build plate and now i have to manually level. There is a large contact acrea why cant the FW select a different part of the buid plate
There is no buzzer on the 200+ but it makes enough noise when the table moves up. Three short runs of the table motor would draw our attention to the fact it is ready to load material or what ever.
