Dear Zortrax-Team!
I have to print something for a custumer ASAP and was stupid enough to update Z-Suite to version 2.24.
I have a M200+, Hardware V1, Serial Number Z9CEE10C7 with Firmware 1.4.
When switching on the M200+ says “The latest version of the firmware is installed. Update not available”
When I want to print, Z-Suite says it needs a firmware update on the M200+ (but the latest version is installed according to the printer)
Internet says I have to register my M200+ first, but there is no possibility to enter the pin from the registration website on my M200+ maybe because of the old firmware.
I tried to update using the firmware-files (2.5.9, 2.5.13) and a two different USB flash drives, but again no succes, M200+ says: “Either the file or the USB flash drive is damaged. Try to transfer the file again or use a different USB flash drive”.
To print my parts quickly, I tried to find an old version of Z-Suite but obviously they are hidden very well, so, just guess, no success again.
I found a solution that is very tedious:
- Copy Update File FW V 2.0 to USB drive, insert USB drive to M200+
- Install FW Version 1.5 from USB drive
Attention, you mus download FW V 2.0, there you will finde V1.5, sounds mysterious
Power off - Copy Update File FW V 2.0 to USB drive, insert USB drive to M200+
Power on - Install FW V.2.0 from USB drive
Power off
disconnect USB flash drive with FW V 2.0 - Power on, now you will be asked to update to newest FW
I hope I could help somebody, it cost me 4 hrs to fnd this workaround
@ Zortrax…the doumentation for this upgrade is nonexistent
Greetings from Austria
Chrstian
