I have a problem with hole edge roughing .
I printed mainly using Z-ABS2 and ULTRAT materials on raft , but both have same problem.
Especially, small hole edge have rougher.
I think the reason is not machine aging, because the problem was since immediately after I bought.
I attached a photo of this.
@KarolinaZ we have the same problem with our M200 Plus printer.
We are facing problems with the print quality even after the very complex repair (replacing the most problematic parts in the authorized Zortrax Support Center). Service said the printer worked fine at their place.
We are printing on ABSv2, Z-Sutie 2.26.0.0., firmware 2.6.5, total printing time ~6500h.
Basically, it is just very poor quality of the print e.g.:
oval hole (not round)
space between printing lines (first layer)
infill doesn’t connect with the outer walls
the last surface is more “melted” than on proper prints
Prints look like from the photo above (on this topic, mentioned by @yukke60)
We know that zcodex is not a problem, because we check it on our other M200 Plus printer - the prints are fine.
Please let me know what we can do…
Thank you,
Martyna
I believe it will be easier to discuss the case via support form rather than on the forum since the printer was already repaired by our Service Center. Attach pictures of your failed prints, .zcodex file and a list of parts that you have replaced so far. We will look further into the matter.
